XLT Won't Stay Running
David Lynch
New Hampshire
1995 Indy XLT
Hi Everyone,
I just picked up a 95 XLT, and I cannot get this thing to stay running. If I spray some starter into the carbs, it will run until it burns it all off, then it will die out on me. I confirmed the pickup line in the tank is good, and the tank has fresh gas in it. I confirmed fuel is getting to the carbs, and I took the carbs out and gave them a good cleaning. I also heard crank seals could be an issue. While I had the machine running on starter from the carbs, I sprayed some starter down into the PTO seal, and it didn't change anything so I think that seal is fine. Not sure where to go next with it...
Make sure you pull and clean pilots also be sure the inlet needles are supplying good fuel flow. To me it sounds like a fuel flow issue.
