ProX00
I am having a really hard time removing my primary clutch. I bought a brand new clutch puller from Bikeman but it is not budging. Even tried the water method about 5X. No luck. Sled is not rusted or even show any signs of wear. Not sure why this is so stuck. Is this a common problem? I tried to heat the shaft as well. What else can I do? Is it ok to use an impact? I have not wanted to force it....I've never had to use that much force to remove clutches in teh past. This is the firttime this one is being removed.
