PCV launch control
Is that with a 19-032 PCV? How much was involved to get it working?
It’s a pcv that’s for axys 800.
Not hard to hook up. Micro momentary switch that’s $1.00, some 22 gauge wire, put into pcv in input #2, and set it up on pcv on computer.
The thing I don’t like after testing it today in shop is it doesn’t build pipe heat, advances timing by 7(instead of retarding), leans out fuel to 16:1.
This program was definitely made for 4 stroke bikes not two stroke engines by dynojet . That’s the way it seems to me by looking at timing on sled in launch mode and afr.
I’m going to email dynojet about the launch mode program
Ok thanks. If it doesn't build pipe heat then it kinda defeats the purpose. I'm running the same PCV. It will be interesting to see what Dynojet says.
I wondered if it builds pipe heat when someone posted this elsewhere.
