Nothing works on the cluster
Dirty Red Neck
WI
95 Polaris Indy 500
99 Polaris 700 Triple
I have a 97' 700 Polaris Ultra and the lights used to flicker and now everything is gone. I figured maybe a busted wire so I got into it and found the yellow wire in the photo broken. I think maybe I did it trying to get the plug loose.
It is connected to that plug with a purple, yellow and yellow wire and jumpered to the main plug at the handlebar stem, its broken about flush with the plug so the question is, what does that wire do?
Second question, once I get this wire fixed, any ideas why the flickering and then the loss of all lights?
Any help is greatly appreciated.
DRN
DRN
Have you tested the voltage on those wires? Could be a feed for accessories. Flicker could be a short or corroded connection.
I assumed it was likely a bad/corroded wire which was why I started at the bars, checking all connections and dielectric greasing them. Once I got to the main plug that was when I saw the pulled wire. The plug it is in is plugged in to something so it doesn't seem like an empty accessory plug/wire. I can splice the wire back, I'm not worried about that, I was more curious as to what it was for/doing? The sled started like nothing happened but I don't know much more than that.
I think you are the correct path, sometimes the light will flicker if the bulbs it out of wack in the hood.
Perfect. I didn't think about the bulbs, I was thinking wiring, I'll look into that as well. Thank you.
