Is honing still required?
Rob in Ottawa
Greely, ON
I fully understand the rationale behind honing, howeve I question its requirement with today's nikasil cylinders?
The last 2 top ends I have done, the cylinders still had cross hatching present,
so is it still necessary, what's you thoughts?
I do it as the nic is very hard
Need that cross hatch to seat rings
I'm sure some will agree, some won't
Check out the rational for Plateau Honeing--- talk with Dan at Indydans, Dan put a short post on SNOWEST last year ( I believe) good read. I have a shop here who will do it also with good results.
gtwitch in wyoming
To ensure cyls are straight / Nik is level with no puddling / surface is optimum for new rings to seal, mine are done at Bondi's with a bar hone. Was a fluke I ended up there the first time when my former go to guy was not available to bar hone. Turns out Nik had ever so slightly puddled around the exhaust ports.
