monte44
- Messages
- 14
- Age
- 48
- Location
- Minnesota
- Country
- USA
- Years Snowmobiling
- 30
- Snowmobile
- 1995 indy sport, 1996 indy lite
Need some help on carbs on a father/son 98 xc 600 project. We have re-rung and replaced crank seals has good compression and passes a leak down. we have installed new Vforce reeds. Problem we are having is poor idle seems like it's loading up will barely idle. It currently has 185 mains and 40 pilots 1 turn out on the screws I have vacuum tested the needles and both hold. The float pins have been JB welded. I do know that these can be very fussy to tune and sure hear and read a lot of problems with the keihin carbs. I have the Polaris throttle adjusting tools. There seems to be a lot of fuel spray in the air box but when I use the choke it does not seem to effect its running? Hope that makes sense. ANY HELP WOULD BE GREAT. THANKS
