Hand Warmers
Muffin
Moderator
Moderator
Athens, WI
Yamaha Nytro
Yamaha Viper
Anybody else have problems with the stock hand warmers. I have a brand new Switchback and the left one gets nice and hot and the right gets lukewarm at best
I started off with RH heater not working at all, dealer replaced then the LH would barely get hot while the replacement RH was smokin hawt.
Gave up on the dealer n replaced the LH with the alum bar version (which I suspect they'd also put on the RH side but dealer says no) on my own dime. All I can tell you, now both heaters are insanely hot hot hot.
This aluminum bar heater. Is this a Polaris or aftermarket part. I'm still learning Polaris as I've just come over from Yamaha.
Install the cork under the grips and do spray foam inside of the handle bars. You can find the threads describing doing both either here or on hcs.
Early build / Ltd came with alum bars + higher output heaters. Even riding last two days at extreme temps, cycling bar heaters off n on low..........yea they get that hot.
