DeanAndon
- Messages
- 3
- Age
- 55
- Location
- Pilot Mound, Manitoba
- Country
- Canada
- Years Snowmobiling
- 5
- Snowmobile
- 1998 Ultra touring
I have a 1998 Ultra Touring and blew the center piston the other day, it was running totally fine for an hour, about -15 celcius, on a groomed trail, the machine had a fair amount of white bluish tinged smoke when idling, The oil light flashed on for a min. rode for about 30 miles stopping occ, cruising at 40-50 mph and bogged out, the oil light flashed on a couple times, started it and went for 1/4 mile, same thing one more time, then trailered it home, when loaded on trailer started to hear a ticking. the carbs were cleaned at beginning of season, needle jets at stock, always idled smooth. removed top end, water pump ok, center piston scored, outside 2 totally fine, wrist pin seized in piston sleeve, not bearings. attached are pics of center piston and plugs, did it run lean? antifreeze leak? any ideas would be appreciated, ask if you need more info, Thx
