clutching machining?
I'm running a gates belt,so is haulin,doc,bigfuse ,pros,etc....
Works and wears good . Plus it's cheaper.
I'm gonna try an epi and Carlisle this winter too.
Good your getting your clutch balanced and machined. It will run a lot smoother plus less stress on other parts too. Make sure you get your clutch indexed for the belt your using.
I would leave your clutching the way it is and try first.
Can't wait! Talked to dan and he said that he sells his new weights with heavy tip weight that will be installed in my clutch. Will the heavy tip weights pull the 50-44 full progressive helix? When its time ill send in a new gates belt for indexing
Tip weight helps as the 10 series don't have enough tip weight for the axys with the clutch sheave degree in my mind . To fast an upshift needs weight to pinch belt up top, in my opinion. Which 10 series don't have.
Try his set up first.
I know he likes running heavy weight and light springs too.
Try it
