Clutching axys 800 155 8-10 ft?
Rmk5899
Mn
2016 rmk 800
Anyone have any good clutch setups for 16 axys 800 155 8-10k ft? Belt driven Factory gears
Sled has ssi pipe mod
Rider 190lbs plus riding gear
Have both tss04 clutch and team tied
Open to options on both
Thanks
weight , suspension, track lug and gear ratio plays a big role in clutching.
The pipe mod is not friendly when motor is optimum and hotter. Falls off hard.
But, you can start with something like this
Try a set of CPC IT ( 60-70 gram)Adjustables . Start with around 63 grams+. 120/310.
46/42 full progressive helix and 140/220 spring
Thank you for the info. I will definitely try this setup in a few weeks when I head to the mountains.
Have you liked the full progressive helix better for 8-10k feet?
I take it this setup is for the tss04 secondary?
I have a 2018 pro rmk with chain case 3 inch track,,ggb can. low elevation.. I would like to gear down and put a clutch kit...what is the best kit and gear ratio I can use.. I love to stand it up!!
also I weight 190 pounds no gear
