Axys driveshaft bearing fix kit
Snoforlife
Maine
'18 XCR Switchback 800
Haven't seen it posted here. I just bought and installed this Axys driveshaft bearing fix kit on my '18 XCR. It makes the bearing greasable.
If you contact Northstar Performance through facebook with your e-mail they will send you an paypal invoice for the kit. 45$ shipped in the U.S.
a>
AF1QipMHcNKsUYGbkD0QfFBAPZi8NfD4V-FkioHt4dHd
AF1QipNlUKkOal5LW7JwPJKSziF1cn6LQ-Un6pNSInDI
a>
I wish all sleds had this.
a>
It can't be that hard to drill the flange and put in a grease nipple.
a>
Is there a cork gasket between the tunnel and the flange?
Yes they are. I’ve never seen the kit but I’d assume you have to dig out and remove that outer seal on the bearing and don’t touch the inboard seal of the bearing.
Yep remove bearing seal and just grease it. The problem is the factory white lithium grease is garbage and most of the time dried out. My sled has 500 miles and there was barely any grease left in bearing. Good way to smoke the whole bearing. Now i can just grease it whenever in a few seconds.
