please put the link for is recepéIt's a stock Axys just tweaked to work better then stock. Pros800 helped the guy out with my knowledge. Glad it works .![]()
Align clutches
Belt to sheave at 0.015"
Spider to tower 0.003"
Machine primary for overdrive
Let secondary float 0.120", 0.060" in from tool,0.060" out from tool.
Slp torque strap
Adjust belt deflection so track spins on stand ,but doesn't squeal while idling.
Let track hang 5/8" freely
Lower fts to one inch, pull limiter tight when ur sitting on it and back off one inch (need someone to help do this )
1.70 ratios with ripsaw or cobra
1.80 ratios with 1.75" and 2" lugs
Softest suspension you can handle with light ski pressure, but can turn with shapers
Chain looser then stock spec
This is some
If you're studded only. Pull limiter strap so both ends are about 1" apart.Lower fts to one inch, pull limiter tight when ur sitting on it and back off one inch (need someone to help do this )
Can you explain this step for me a little better please? I get the fts but the limiter tight?
This stops some of the transfer on assault from being a wheelie machine and a better hole shot machine.View attachment 1891
Toms learning from a smart guy LMFAOProS800 (Tom) has been posting vids on the fb groups of him waxing 850s, cats, and sidewinders the last couple days with his SB. And he doesn't even have his A1 setup in it right now. Ice drags in St. Germain
