sschmitty32
- Messages
- 11
- Age
- 55
- Location
- Racine,Wi
- Country
- USA
- Years Snowmobiling
- 5
- Snowmobile
- 2017 Polaris Rush 800 Pro-S
Curious if anyone has run or currently running Straightline’s NOS system? Any feed back would be great.
What kind of octane did you need to run on the 40shot?I installed one years ago on my 2006 600 RMK. Still have it on. Works great. The hardest part was finding the proper 1/8 to 1/16 plastic reducer fitting for the fuel line to feed the fuel nozzles. Acklands Grainger in the US was the only place, and had to order 10 or 20 of them at once. I plug the power and ground into an unused connector in the wiring harness by the steering hoop when I am going to use it. 400 rpm gain on the button, supposed to be a 40hp shot. Can have the throttle pinned at 70 mph, hit the button and the skis pop up instantly stay off the ground as long as you are on the button. The power is exactly the same until the bottle is empty. I have the bottle mounted upside down to my fender in front of the muffler, used a boondocker nitrous bottle bracket, bolted to the fender.
I run pump gas 91 octane. Just adjust the fuel screw properly on the valve for the additional fuel.What kind of octane did you need to run on the 40shot?
Thanks racerdave. I see the traffic on Hardcoresledder isn't what it was, a lot of the technical posters are gone? Is this the new hangout?Good to see you here Pockets
