2017 Assault Specs
axxasult
SK
2017 Assault 144
2017 600/800 SWITCHBACK ASSAULT 144
. AXYS IFS: 42.5" Ski center to center distance
. 0.531" diameter SwayBar, same as Pro-S, reduce inside ski lift
. Front bulkhead cooler, tunnel coolers/protectors
. IGX 144 Rear Suspension, Tipup rails
.. 2 rear torsion/hairsprings
. W/E Comp. Adj. piggyback needle IFS
. W/E Comp. Adj. piggyback NO needle FTS coilover shock
. W/E Comp. Adj. piggyback NO needle RTS no coil shock
.. NO SnowCheck upgrade option for Hi-Lo speed compression adjustment of shocks
. Message Center 4.3" LCD gauge
. Integrated semi-rigid underseat storage.
. ProTaper 7/8" alum. flat Handlebars, 3.5" (89mm) Riser
. PowderTrac Hybrid Running Boards 56% open space
. 7.063" Chaincase center distance, like Rush/SB137
. 600cc Gears 1.86 22:41-70 1.35" Cobra, 2.11 19:40-68 2.0"
. 600cc Gears 1.86 22:41-70 1.75" BackCountry INTL
. 800cc Gears 1.74 23:40-70 1.35" Cobra, 2.10 20:42-70 2.0"
. 144 x 1.352 Cobra 2.52" pitch / 144 x 2.0 Series 4.0 stock OR snowcheck
. INTL 600 version 144 x 1.75" BackCountry 2.52" pitch
. Black Pearl stock color with alum. tunnel rails & spindles
. 600cc SBA $12,199US/13499CDN stock, ES + $400/500CDN
.. $12,599US/13899CDN Snowcheck colors & options
. 800cc SBA $13,499US/14599CDN stock, ES + $400/500CDN
.. $13,899US/14999CDN Snowcheck colors & options
AFTERMARKET TRACKS AVAILABLE for the Switchback Assault/SP 144
. 144 x 1.22" Ice Attak XT 2.52" pitch 47 lb. full clip studded Camso# 9203H 1ply
. 144 x 1.352" Cobra 2.52" pitch 44 lb. full clip Camso# 9107H 2ply
. 144 x 1.5" CrossOver 2.52" pitch 50 lb. full clip Camso# 9003C
. 144 x 1.6" ICE Cobra 2.52" pitch 50 lb. full clip studded Camso# 9315C 2ply
. 144 x 1.6" Cobra 2.52" pitch 49.5 lb. full clip Camso# 9316C 2ply
. 144 x 1.75" BackCountry 2.52" pitch 46 lb. full clip Camso# 9143C 1ply
. 144 x 2" Challenger 2.52" pitch 53 lb. full clip Camso# 9875M 1ply
some more. some things not in the first post
ENGINE & DRIVETRAIN
Disc Brake Type AXYS™ Radial
Drive System Type Chaincase
Drive/Driven Clutch P-85 / TEAM® LWT
Exhaust Single, 3 Stage VES w/ Smart Actuator
Fuel System Cleanfire® Injection
Ignition Clean-Fire 3D
Engine Type/Cooling Liquid Cooled
Cylinders-Displacement (cc) 2 - 795
Bore x Stroke (mm) 85 x 70
SUSPENSION
Front Shocks Walker Evans® Comp. Adj. Piggyback Needle
Front Suspension AXYS® Front Suspension
Front Track Shock Walker Evans® Comp. Adj. Piggyback
Front Travel (in./cm.) 9.5 / 24.1
Rear Suspension IGX 144
Rear Track Shock Walker Evans® Comp. Adj. Piggyback
Rear Travel (in./cm.) 16 / 40.6
Ski Type PRO-STEER
Track Width/Length/Height (in.) 15 x 144 x 1.35 Cobra OR 15 x 14 4x 2.0 Series 4
DIMENSIONS
Fuel Capacity (Litres) 12 / 45.4
Overall Height (in./mm.) 54.5 / 138.4
Overall Width (in./mm.) 47 / 119.4
Person Capacity 1
Ski Center Distance (in./cm.) 42.5 / 108
Estimated Dry Weight (pounds/kg) 456 / 207
Overall Length (in./mm.) 125 / 317.5
FEATURES
12v Outlet Accessory
Color / Graphics Black Pearl
Electric Start Option / Accessory
Fuel Gauge Electronic
Hand & Thumb Warmers Standard Adjustable
Heated Passenger Grips N/A
Mirrors Accessory
Rear Rack/Tow Hitch Accessory
Reverse PERC®
Seat Type AXYS™ Performance
Security System Option / Accessory
Speedometer Digital
Storage System Standard
Tachometer Digital
Temp/Low Oil Light High Temp/Low Oil Light
Windshield RMK® Mid-Matte Black
Handlebar Type Aluminum ProTaper®
Riser Type 3.5" (89mm) Fixed
Forgot to post this incase your trying to figure out space for something on the back. 15 3/4" wide. 24" to back
The Burandt small bag will fit but the large won't. There's a Premium bag that's pretty big that is made for the Assault.
Polaris 2.52 pitch is an 8 tooth.
Also should mention. The 144"x14"X1" hacksaw will work on the assault too.
It's 6 lbs lighter then the cobra. I only suggest this if your going to seriously stud it.
Thank you for the reply. No studs for me. Ordered 2.5 Peak through dealer, Finnish models have 2.0 challenger and I have bad experiences with that track. It has no grip even on a 600 RMK, lugs bend too much.
Gonna have to put 2.86 drivers for it though
anyone know if the 2" track comes with fill clips? i didnt look that close at the show
my backcountry X track i had last had full clips. dont think it really makes and difference anyways
