2015 pro s 800 missing
whitefrost
kennetcook
2015 pro s 800
so I started my sled up and let it warm up..i shut it off to put my suit on and when I started sled back up it made a small pop and it started idleing very low and half missing.. almost seemed like a fouled spark plug..took it for a drive and it would clear up some but the det light would come on when I gave it full throttle..it comes on every time I pin it and top rpm is slow to climb ….also it will backfire some too if I give it too much fuel...can anyone help me out..sled has 4500 miles on it
tore it apart today..clutch side piston pin broke and let the ring turn catching port..the other piston is extremely loose in cylinder but showed 130 lbs of compression
