2012 Adventure smaller replacement battery needed
arctic sloth
Saskatchewan
2012 Polaris Adventure
Looking for a smaller battery for my 2012 Adventure. To remove and replace the stock battery I have to remove a lot of parts including the muffler. Is there a smaller battery that will slip in and out without having remove parts?
Thanks
Have you looked into the Odyssey Battery?
SOLUTION FOUND I ended up going to a battery "super store" and found an agm that's the same width and height but 1 1/2 inches shorter in length. Works good..slips in out with the muffler in the machine...its tight but it works. Lots of power ...spins over good. I left the heat shield off and made a plywood spacer with a fish wire attached to take up the space. No problems so far. Description on the invoice is AGM12A-A motorcycle battery.
Any pictures?
