Tunnel Protectors
Brad Patterson
Renfrew
I just picked up my snowchecked Pro S LE switchback yesterday and I'm going to stud it with 1.45" studs. Can you put sliders on the grooves in the tunnel. But are you guys putting anything on the front heat exchanger?
You can add sliders to the groove. You need them if you run long studs. The ones I used are, Garland part #15-5700-0-02-01. Most Polaris dealers don't know about this. They are not listed as as axis accessories.
I didn't add any protection in the front heat exchanger. I run long studs and haven't had a problem.
