clutch weights?
PerformanceRich
CT
What clutch weights are you guys liking on these axys 800's? Seems like a lot of people use Polaris 10 series. But from what ive heard, weights make a lot of difference. Was looking at heavy hitters and ssi pro mags? Or just stick with Polaris 10's? What do you think?
There so many options I got to SSI pro mags will let you know how they work when it snows. There is a picture of here of a bunch of different ones all stacked up that is pretty good
10 series aren't working the best , not enough mass at the heel or tip.
That's ok, I got them to work. Won races with them too!!
I know some people don't like to give out info, but a lot of people seem very generous on this site. Is your setup similar to 120/310 primary, 140/200 secondary with a 50/44 full or 66/44.46 compound with the 1.74 gearing?
For some reason this site isn't working for me.
Your close to my setup, but not the same.
What weights are you using?
10 SERIES WEIGHTS WILL WORK JUST FINE, BUT YOUR GOING TO HAVE TO ADD MASS TO THEM. 2GRAMS IN BASE BY THE PIN AND 2 GRAMS UNDER THE TIP. THIS WAS ALL DONE WITH THE STOCK WEIGHTS. TESTED AND PROVEN ,ONCE SET DIDENT MESS WITH THEM AT ALL LAST WINTER AND PUT 2K ON THEM
I bought a set of 10 series 70 gram weights and clamped all three in vice and took 1.5 grams out of center of the weight. (all at same time to make sure they EXACT same)
my theory being its now a 68.5 gram weight with heavy heal and tip.
It works great but take your time and buy a good scale to make sure there all the same weight. the set I bough were .5 grams different outa the box! I have them all the same down to the thousands of a gram
Kinda what I was getting at , should have been clearer...
