Compression numbers
JWBERT427
McFarland
2016 Polaris SB Pro S 800 ES
I have a 2016 SWB 800 Pro S with 108 hours on the engine,
(around 4000 miles I think) I just did a compression check
on the engine stone cold, (could not run it right now) and
came up with 110# on both cylinders, is this ok?
Depending on what guage you have the number is whats important. I have a cheaper autoparts store guage and both my Engines read 110. I have had the sleds since new and also documented the Compression reading, so I know my base numbers and current and I am only off by maybe 1-1.5psi since new.
Good to know, I was wondering about the accuracy of my gauge, unfortunately I did not take
a base reading when I bought the sled new.
Not all compression gauges read the same.
Personally, I would replace the pistons .
Compression numbers won't show how much piston wear and rocking is going on in there .
My buddies '16 pro s broke a skirt at 4500 miles . Was running perfect up to that point .
In the real world of 2 strokes, we seem to expect way to much from these motors .
Motor cross riders replace every, season, every race, every 10 hours.......
Whatever the case may be .
Key to decent piston life is being anal about proper warm up and running good oil. Life expectancy, I'd think 7000 miles is not unreasonable.
Follow up? How did the sled perform after this post?
You should use the compression numbers for comparative readings and not so much the number itself for reasons already mentioned. I have a 2019 800 Rush with over 17,000 miles on it and still runs great. I don't care what the compression numbers are, they won't tell you much. The only engine related failure (so far) is a exhaust valve stem broke off at the blade. I'll ride it again this year and put somewhere between 5 and 7 thousand miles on, maybe I'll tear it down after this year.
